Gauge Cluster
Old Sep 3, 2025 | 10:07 PM
davidl22_85vet's Avatar
davidl22_85vet
5th Gear
Default Gauge Cluster
The digital gauge on my 85 vette is not displaying the rpm’s any idea how to address.
Old Sep 4, 2025 | 09:36 AM
s carter's Avatar
s carter
Everything else is good speed, oil pressure all bases covered just No tach. You're probably unplugged or the Tach filter has failed, so start simple go to the distributor look for the plug next to the power lead make sure it's seated next follow the wire behind the motor (Tight quarters) make sure the wire and out of the filter are not broken off
