??? newer heads question???
Old Feb 16, 2003 | 11:20 PM
jjmac_dragracing's Avatar
jjmac_dragracing
Default ??? newer heads question???
I just bought some 91 113's on ebay and I was told that my BRAND NEW COMP CAM PRO MAGNUM 1.6 RR'S that I put on my stock 85 heads won't work. HELP!! is this true do i have to get the self alining ones or is there some way thay I can use mine still ANY INPUT WIL BE HELPFUL THANKS!!!
Old Feb 16, 2003 | 11:24 PM
scorp508's Avatar
scorp508
What part number are you using? I'm using comp cam pro mag rockers on my 113 heads.
Old Feb 16, 2003 | 11:51 PM
jjmac_dragracing
Default Re: (scorp508)
cca-1302-16
Old Feb 16, 2003 | 11:58 PM
scorp508's Avatar
scorp508
You should be fine as long as he did not upgrade the heads to 7/16" rocker studs. :yesnod:
Old Feb 17, 2003 | 12:08 AM
jjmac_dragracing
thanks i will find out if they work next week when i get them and i don't think that he did anything to the heads he said they were totaly stock just pulled of a 91 vette with 80,000 miles i'm going to have my motor guy go throught them and bowl houg the valves and port match them to my intake and i might move up to 2.02, 1.6's i'm not sure yet. I really want to stroke it this year but I might have to wate
Old Feb 17, 2003 | 01:46 AM
gtsyellow's Avatar
gtsyellow
Default Re: (jjmac_dragracing)
you just need a set of $19.95 guide plates. the stock 113 plates are loose & just used for production.
Old Feb 17, 2003 | 01:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will need both hardened guide plates (toss the stock non-hardened guides) and hardened pushrods.
Toss the oil shedders, install Ti retainers and 10deg locks also.
The 2.02/1.60 won't work without new seats but you can have him shave the intakes to 2.00. Either way have the valves necked and back cut.
Don't foreget to have new valve guides, upper and lower seals installed too.
Those RRs should be fine on stock 113 studs; install new springs too.
Properly worked those heads should be worth 20-25hp.
[Modified by 65Z01, 1:03 AM 2/17/2003]
Old Feb 17, 2003 | 10:27 PM
jjmac_dragracing
Default Re: (65Z01)
I got my heads today and I'm going to my motor guy tomarrow get the work done to them i'll tell he what you said and I allready have hardened push rods and brand new stiffer springs so I'm all set their.
another question ?? Is it worth the extra money to go to the 2.02/1.6's or not
Old Feb 17, 2003 | 10:29 PM
scorp508's Avatar
scorp508
Not unless you've got (or will be doing) some serious changes like cam/intake/exhaust. Make sure you pick up some hardeneed guideplates if you don't have those already.
Old Feb 18, 2003 | 11:15 PM
jjmac_dragracing
look at my signiture i,ve got a cam but am go to go bigger thinking .500 lift area i have the eghaust but no hedders yet and others to
Old Feb 19, 2003 | 02:01 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Don't know what your 113's flow right now or what they'll flow after the work your head guy is going to do, but my 128's w/ my port job, 4-angle valve job, and 1.94 intake valve flows 245 CFM at 0.500" lift (and I believe ~248 @ 0.550" if memory serves...I'll flow them tomorrow and check since the motor's apart anyway) If you're just looking at going to a 0.500-0.550 lift cam, I'd personally leave the 1.94's in there, as you'll keep your low lift flow.
To ??? newer heads question???
