Headlight help please - 95
Old Feb 17, 2003 | 12:45 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Headlight help please - 95
On my way home last night, i flipped the headlights on, and the driver's side one only turned about halfway. the pass. side light goes all the way around like normal, but the driver's side doesn't want to go but halfway...
any ideas as to what's wrong? i haven't had the chance to mess with it yet, i figured i would try and manually open it in case the motor was shot or something, but was wondering if anyine else had had this happen to them, nad, if so, what did you do to fix it?
thanks
:D
Old Feb 17, 2003 | 01:16 PM
mike72's Avatar
mike72
Default Re: Headlight help please - 95 (_freakmonkeydogboy_)
sounds like the bushings are shot. You can get replacement bushings for a few dollars and the fix is not too difficult.
Old Feb 17, 2003 | 01:21 PM
FSTRNU's Avatar
FSTRNU
Default Re: Headlight help please - 95 (mike72)
:iagree: Samething is wrong with mine I need to fix but just dont have the time lately
Old Feb 17, 2003 | 01:31 PM
Steel Blue 91's Avatar
Steel Blue 91
Check to make sure nothing has blocked the headlight travel. One of my fan relays had managed to come loose (relay cover had cracked and the relay fell off the clip) and was blocking the path of the headlight. If the pathe is clear, then it may be time for bushings.
Old Feb 17, 2003 | 03:57 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: Headlight help please - 95 (Steel Blue 91)
Did the bushing r&r last summer. Fixes this like new. About $10 and under two hours time. Be sure to get bushings for both sides. :thumbs:
Old Feb 17, 2003 | 06:40 PM
_freakmonkeydogboy_
Default Re: Headlight help please - 95 (brdd)
well after messing with it for 3 mins. or so, i got it to work, i think some wiring harnesses were just in the way...no biggie, but thanks anyway
:D
To Headlight help please - 95
