4+3 noise
Old Sep 21, 2025 | 04:05 PM
max76's Avatar
max76
Default 4+3 noise
Hi guys,
I'm Max from Italy.
Today I'm going to test a 1987 4+3 convertible C4. It's run great, the OD work well, but when the OD is not engaged I listen a noise...it's like the differential noise (like if there's wrong oil), but if you engage the OD there isn't noise, it's all quite...
The car had 80k miles, but I don't know nothing about gear maintenance...
Someone can tell me what could be this noise? Only when OD is not engaged...
Thanks in advance guys...
Old Sep 21, 2025 | 04:12 PM
IHBD's Avatar
IHBD
Pro Mechanic
It is the carrier bearing in the Overdrive. Parts are not available at any price. Don't buy the car.
Old Sep 21, 2025 | 04:36 PM
max76's Avatar
max76
Really? But the problem it's when you drive normal, without engage the OD...Can you explain how the carrier bearings works? There are no spare parts for the Doug Nash?
Old Sep 21, 2025 | 06:37 PM
IHBD's Avatar
IHBD
Pro Mechanic
Old Sep 21, 2025 | 09:23 PM
conniekalitta's Avatar
conniekalitta
This particular bearing in the 4+3 is special in that it takes a heavy amount of axial load in direct drive. In 1984 and 1985, a fair amount of these overdrives had bearings which were “pre-loaded” far too tight from the factory. Thus, they received poor lubrication and eventually overheated and failed between the manual transmission and overdrive unit. A characteristic sign of this failure was a “whine” or groan of sorts. This was mostly solved by 1986. Many early 4+3 Corvettes made it about 30,000 miles before the overdrive had to be replaced, typically under warranty.
I can imagine this issue can happen to all 4+3s, regardless of the year, if they were poorly serviced throughout their life. This is why the fluid changes are so important. Take IHBD’s words, run from this car. This is not the one.
Old Sep 21, 2025 | 11:11 PM
wolf_walker's Avatar
wolf_walker
I think that's the only problem my 156K 86 doesn't have lol..
I consider a 4+3 car to be buying the fact that it has the heavier rear diff and clutch and such already for whatever trans you eventually upgrade to.
The doug nash setup lasts however long it lasts and then you either pass it on or spend the money on another trans. I'm not looking forward to that
day but it seems to be about the size of things right now. It's still better than an automatic.
One would have to really want the early interior and body and engine (like me) to pick one of em over the later six speed cars.
Be a different matter if they were economically and correctly fixable.
Edit: Just google'd this for the hell of it, is this the bearing?
https://www.transmissionpartsdistrib...4-88-corvette/
I've bought from those guys before and they seemed legit.
Old Sep 21, 2025 | 11:26 PM
conniekalitta
ZF cars are also on a timer. Good luck finding anybody on the continent who will touch an S6-40 with a thousand foot pole.
plus:
^^^ I believe THIS is the bearing. Carrier and everything. I found this image many moons ago and I guess someone was lucky enough to dig this OEM bearing and carrier out of a parts warehouse somewhere.
Lord knows if any other bearing would work… though it’s certainly possible.
Old Sep 21, 2025 | 11:46 PM
wolf_walker
Wish the part number on that Elges bearing was fully readable. They are still around, could at least get size off it. That GM part number appears to be the later "fixed" version.
Old Sep 22, 2025 | 12:51 AM
IHBD's Avatar
IHBD
Pro Mechanic
Bill Boudreaux in Phoenix Arizona would vehemently disagree with you. zfdoc.com
Old Sep 22, 2025 | 01:03 AM
wolf_walker
I think you may have misunderstood my post. None of that matters, just the part number on the bearing itself to begin the process of verifying that it isn't available. That starts with the bearing, the manufacturers isn't GM, it's Elges.
The bearing can usually be pressed in/out of the housing. Schaeffler owns Elges now so that might complicate things but it's where I'd start.
Old Sep 22, 2025 | 01:44 AM
conniekalitta
That is MY picture. That is MY part and my box. Appearances can be deceiving.
You have to be careful looking at things. It looks like it should be a new part. Not only is it a used part, it is a junk part. I should put it on ebay for $900.
I found the image on Google a while back, now I’m assuming it’s a thread you replied to. I was obsessed with 4+3 knowledge back in university. Hell, I’d keep that bearing and carrier just for the novelty even if it IS scrap. Piece of GM history. Ugly, terrible GM history, but that’s the story of every decade.
And I guess the 4+3 and ZF guys can relate to one thing; only one guy in the country can fix our transmissions. And we enjoy our third pedals.
Old Sep 22, 2025 | 01:49 AM
IHBD's Avatar
IHBD
Pro Mechanic
I don't care about any of this.
Old Sep 22, 2025 | 01:55 AM
wolf_walker
So that means you didn't note the part number on the bearing?
Old Sep 22, 2025 | 03:18 AM
max76's Avatar
max76
I don't care about any of this. My 4+3 works. And I have another complete 4+3 on the shelf.
The OP asked about purchasing a car with a noisy DNE carrier bearing. I suggested that he NOT purchase it. Avoid the headaches. Not to mention he's in ITALY.
No one has mentioned the thrust washer. Those aren't available either.
Hi IHBD,
i apreciated your comments and your suggest...i'm so sad, because the car was in good shape and a good price (remember all, i'm in Italy)...but...if there aren't spare parts...Unfortunately i don't know much on maintenance, this car is in italy since 2014 and had 6 owners!!!! Before 2014 was an Austria car....
This is the Vin of the car: 1G1YY3188H5121142
I see 5speed.com had rebuilding kit and bearing, but they are not available at the moment...really sad...
Old Sep 22, 2025 | 03:19 AM
max76's Avatar
max76
Nobody try tu put a zf 6 speed in place of the 4+3? It's a possible things?
Old Sep 22, 2025 | 07:54 AM
max76's Avatar
max76
Sorry for all my questions...Can i use the car always with the Overdrive engaged? Using the gearbox with this solution the carrier bearing it's blocked and the car run good...or not? It can still damage the gearbox?
Other question, isn't there the possibilities to replace the 4+3 gearbox with a standard 5 or 6 gear shift?
Old Sep 22, 2025 | 11:37 AM
jdjenk's Avatar
jdjenk
Don't buy the car
If you really want it, get it and realize you'll need to swap something in it. Maybe you can get it cheap enough to justify yanking the trans and swapping. I don't know what you can get in Italy, but a TKX is the best swap here in the states, a T5 if you like to live dangerously but those are getting harder to find.
My 4+3 works still at 125k, but if it ever goes its getting a TKX or the car is getting junked. They're unrepairable at this point.
To 4+3 noise
Old Sep 22, 2025 | 12:09 PM
wolf_walker
Cannot effectively run it with the overdrive always on. The pump is on the output shaft of the OD unit so until it's spinning enough it will not make enough pressure.
We usually do the opposite here, disable the computer control and just use it as a 5th overdrive gear manually with the switch to minimize wear on them.
There really is not a fool proof solution other than replace the trans with something else. You might find a good used one, or you may not need the unobtainable
parts (it's a very simple unit otherwise). Pretty much buying something with an expiration date on these.
Old Sep 22, 2025 | 05:22 PM
max76's Avatar
max76
Originally Posted by jdjenk
Don't buy the car
Hi...what is the TKX?
There's a website to see these gearbox?
I don't understand what is the piece in the OD that create all this problem...can you show me a picture?
Old Sep 22, 2025 | 07:47 PM
IHBD's Avatar
IHBD
Pro Mechanic
