A/C Issues
To some servicing your own A/C may seem so simple anyone can do it, but if someone dies or gets gravely injured due to inexperience or just plain idiocy I wouldn't want to be the one who encouraged that person.
i purchased some cans of R12 and a vintage fill hose thinking I could recharge my '84 myself. After reading many posts on this forum, Especially ones that Arbee has participated in, I no longer have any desire to mess with it and just roll the window down. So far so good.
Thanks Arbee! I hope more members listen to your (correct) advice.
I guess my post made it seem I was "scared" when really it is about lack of confidence that I won't f@#k something up. I do however work on the car myself, recently I replaced all the u joints (having a quickjack helped a lot). I've also done easier things like replacing KYB shocks with proper Bilsteins, brake light switches, alternator, cooling fan motor, EGR valve, CTS sensor, door panels and seats, all vacuum hoses and most of the other things that come up on a 40+ year old car. At 68+ years old getting up off the garage floor aint getting any easier but I carry on.
I know you meant well and I apologize. I made it sound like I was singling you out and should not have done that.
But yeah, I only mentioned it because legally the person selling the R12 is supposed to ask for your EPA license, since it's controlled. I don't know if it's the same way, but it's literally a 10-minute test you can take online and send in $50 bucks to get licensed.
I appreciate reading your posts because there is a lot of knowledge being shared by someone who KNOWs what he is talking about. Air conditioning and refrigeration is something that I have no formal training in.
Tinkering is part of my nature so over the years I have worked on many AC systems and been successful so far.
A question if you don't mind. Does cleaning the aluminum condenser on the front of your car's radiator make any sense? I have some Coil Cleaner and have suggested to some folks with problems that a clean condenser would be helpful at getting rid of the heat sent up there. On my C4 I have cleaned the condenser with coil cleaner and it was much cleaner looking afterwards. With this being regular maintenance on Home AC system keeping the coils clean to help get rid of the heat I was wondering if the AC Condenser cleaning is worthwhile on a car's AC system? I am very careful to use low pressure water to clean up afterwards to not damage the cars paint or condenser.
I have several patents regarding Passive Cooling as I designed working systems for Westinghouse that was used in the deserts of the middle east. I understand passive but not the refrigeration principles.
Thank you again Arbee, we really appreciate you trying to explain the principles of basic refrigeration and AC system. You do a great job making it understandable and that is a real talent all in its own! Like I mentioned before, you teach us valuable information and that is something that I really appreciate!
With an 09 code the compressor will not come on unless the system (computer) is reset. You do that by disconnecting the battery for 30 sec. or so, then bypass the LOW pressure switch, start the car and turn on the AC and the compressor should come on. Then refill the system. The compressor will go on and off recycle rapidly) until there is sufficient Freon in it, then it will stay on. Then disconnect your low pressure bypass and reconnect the plug into it.
Then you have to find the source of the Freon leak.
And measuring pressures, either high or low without the compressor running is meaningless - you are measuring a static system pressure which is equal throughout the system.
Now I wait and see how long the freon lasts in the system.
Thanks again.
