coolant spill on the racetrack
And if you're gonna take it to a shop, make darned sure they know to seal the china walls else you'll be doing it all over again. At least as far down as the intake manifold anyway.
I guess what I'm saying is... it might not be a head gasket at all, but in fact your cyl heads. Since you have to remove the cyl heads anyway to change out the head gasket, I'd recommend having a machine shop look at your cyl heads for a couple of reasons...
1 - Have them magnaflux both of them to check for cracks at the valves.
2 - Have them make sure the heads are straight and not warped after overheating
While they're out, you can probably change out the oil seals anyway, and whatever else you want to do with it... but this would be my recommendation. Sucks... but I've been there.
for china walls I don’t know what to tell them in particular. I had a leak on the old l98, it was sealed with red rtv but I suspect it was too soft. on the 383 they used something grey and held well but now I’m going to a different repair shop
It's what I get for not reading the op and just responding to a post later in the thread.
I was thinking L98 when I mentioned about the china wall but I don't know jack squat nothing about a 383 so maybe disregard, I probably don't know what I'm talking about there when it comes to a 383. Ha.
Sorry.
