Question on fuel
Old Oct 29, 2025 | 06:32 PM
Daveb26's Avatar
Daveb26
5th Gear
Default Question on fuel
Wondering if I can get some advice. Just got a 91 corvette convertible. I changed the fuel pump,plugs,wires,oil,air filter and im still having this problem. 1 the cat cranks but sometimes it take a little bit till it starts. When It's at idel it smooth and runs great give it gas it fine but when driving whe I get to about 45 I start to get like a bogging down or a rumble till I ease up on gas and proceed to give it gas slowly then it happens again in the 50s but when I give it gas fast it starts to bog down and kinda shake and rumble again I have to give it gas slowly and when I try to push it it's bugging down and rumbling the service engine soon light comes on. Any ideas ???
Old Oct 29, 2025 | 08:07 PM
Whaleman's Avatar
Whaleman
Did you change the fuel filter? Dan
Old Oct 29, 2025 | 08:25 PM
Daveb26's Avatar
Daveb26
5th Gear
I am this weekend do you really think all this fuels problems im having can be as simple as a fuel filter.
Old Oct 30, 2025 | 02:57 AM
JD1964's Avatar
JD1964
The symptoms you describe indicate possible fuel starvation so yes, a clogged fuel filter might be the problem.
To Question on fuel
