Steering Column Question
Old Nov 9, 2025 | 09:13 AM
Thowie1974's Avatar
Thowie1974
3rd Gear
Default Steering Column Question
I need some input on an issue I am having with a rebuilt steering column I bought for my 1991 C4. After removing the old column and installing the new one, I went to put in the tilt lever and found the hole was so close to the dash it was almost impossible to get the lever in. After a few attempts to try to adjust the column, i decided something wasn't right, and removed the new/rebuilt column to compare it to the old column. I measured the two from the mounting bracket to the turn signal lever housing and found there an 1 1/4" difference between the two columns. My question is, can the location of the mounting bracket be adjusted or did they send me the wrong column?
