early c4 heater performance
as it routs air differently. Very toasty though on heater/75/auto. My first winter with the car so I'm glad to see it working, spent pretty good money on a NOS programmer over the summer.
cooler when driving vs sitting still? Hard as it may be to believe these aren't just the most air and water tight cars ever made often times.
If you could rig a thermometer in the lower heater outlet you could see if it's an actual difference in output temp when moving vs sitting still or just
a perceived feeling.
I went ahead and bypassed the valve, no real change. I fiddled with adjusting the temperature cable also to no effect. Also went down and manually actuated the doors, it seems like they're moving as they should. I think its as good as it will get, maybe I just have a bum heater core or something. On the bright side the car seems to run a little cooler now that I've effectively flushed the coolant a couple of times.
I'm pulling the heads to finally build the top end of the motor next week anyways, so it is what it is. I'll verify my coolant routing then anyways since I'll have to redo some of it with the new intake, but it looks like I match the book.
