Where does this mount
Old Dec 5, 2025 | 09:13 AM
johnfin's Avatar
johnfin
Default Where does this mount
1985 RH side bracket mounts to this piece. Around the exhaust mani
fold somewhere.
Old Dec 5, 2025 | 11:33 AM
JoBy's Avatar
JoBy
Old Dec 5, 2025 | 12:56 PM
johnfin's Avatar
johnfin
Thats the sensor, not the harness bracket. Look at my picture above.
Old Dec 5, 2025 | 01:01 PM
s carter's Avatar
s carter
Running from memory there might be small hole on the factory heat shield on the exhaust manifold held on by a standard 7mm head
Old Dec 5, 2025 | 05:56 PM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Block.
Bottom screw of bracket of bracket that is bolted to the top edge of block deck.
Bottom screw of outside bracket that goes over inside bracket that is bolted to the top edge/side of block deck.
To Where does this mount
