can anyone recomend a good set of 22# injectors that won't break the bank. I have purchased one sent that was not good. I have had my factor set refurbished. it seems that I have one or more bleeding. fuel pressure goes from 45 psi to 0 in a mater of a few seconds. I have checked the fpr with no sigh of leaking. I have removed the TPI and raised the fuel rail up to see the bottom of the injectors and applied 45 psi with no sign of bleeding. I have removed the 9th injector with no sigh of bleeding. I have added a check valve in the input fuel line.I have pinched off the return fuel line.
I have a no start issue when warm that I haven't resolved after doing everthing that was recommended on this site.
these are a good price, a little noisy and can run lean if not tuned for. But if your going to get a vats delete tune I can change the battery voltage offsets so the d3 will work better.
