code 72 in the abs system
Old Jan 14, 2026 | 05:34 PM
wayoutthere's Avatar
wayoutthere
Default code 72 in the abs system
driveing it,all was good,shut off car, now will not shift out of 1st gear with a code 72 in the abs system,any clues? i reset all the asr cables and it shifted perfect for a day, now back to not shifting out of first and set this code
Old Jan 14, 2026 | 09:58 PM
IHBD's Avatar
IHBD
Pro Mechanic
What year?
9.72 is Serial Data Line Malfunction. Did you access the code with the onboard diagnostics? Were there any codes in the other modules?
Old Jan 15, 2026 | 04:18 PM
wayoutthere
ccm code 41- ecm has a optispark code 16 and 36- abs system has code 72 yes onboard hand held diognostic old gm tech hand held- optispark was throwing code- replaced optispark still throws optispark code 1993 year-
To code 72 in the abs system
