Vacuum line issues
Old Feb 2, 2026 | 10:31 PM
Nathandrott's Avatar
Nathandrott
2nd Gear
Default Vacuum line issues
Hi i just recently bought my first corvette last week and im trying to get it to idle strong. I changed the maf sensor and that helped a little bit but now its bogging down till it almost dies and then it revs up. I went to investigate and saw that all the vacuum lines for egr system have been sniped and i suspect thats my problem. I ordered some vacuum hoses of various sizes and i planned to replace all of my vacuum hoses just to make sure i get rid of all the vacuum leaks but i wanted to make sure i could use that to replace the whole system or if theres any specific parts i will need. I also want to see if im on the right track to getting my car idling strong.
the kit i ordered has 6.6 feet of 1/4”, 3/16”, 5/32”, and 1/8”. Im not a master mechanic by any means im just working my way through one problem at a time with chat gpt, youtube, and whatever forums i can find that are relevant.
Old Feb 3, 2026 | 01:21 PM
topfuel67's Avatar
topfuel67
Make sure to get a factory service manual. These cars show up in the pick ur parts wrecking yards and that’s probably the easiest way to find all the lines. There’s a vacuum line that goes through the firewall to control the hvac. That line is made out of soft rubber and often is rotted. Good luck hunting.
Old Feb 4, 2026 | 12:15 PM
Nathandrott
2nd Gear
thank you for the response. I checked all of the junkyards within a 8 hour drive of me (less then youd think) and none of them have any c4s. I did order some vacuum hose thatll be here friday and hopefully i can make do with that however i may have a few routing questions since some of the hoses are out right missing
Old Feb 4, 2026 | 01:14 PM
2011KLR's Avatar
2011KLR
This thread has a picture of the 84 model year vacuum routing.
84 corvette vacumn system and throttle body fuel lines - CorvetteForum - Chevrolet Corvette Forum Discussion
I don't see that you posted a MY of your car.
Use the Advanced search for 'routing' of the C4 forum and you'll get a lot of results.
To Vacuum line issues
