open air lid
Old Feb 20, 2003 | 04:42 PM
korvettek's Avatar
korvettek
Default open air lid
is there anywhere i can find how to cut out my air lid :yesnod:
Old Feb 20, 2003 | 05:07 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: open air lid (korvettek)
Use the search feature. You will find more information than you need. Like this:
https://www.corvetteforum.com/techti...D=47&TopicID=2
Or you can buy a precut lid and save the original.
Old Feb 20, 2003 | 05:17 PM
hngacurv's Avatar
hngacurv
Default Re: open air lid (Steel Blue 91)
It is a pretty simple process. You are basically just cutting out a rectangle in the front of the air lid. I chose to cut only the front flat surface off using the 1st bend as a guide. I used a Dremel to cut it off and smooth down the cut edge and then spray painted it black.
[Modified by castivers, 5:17 PM 2/20/2003]
Old Feb 20, 2003 | 05:33 PM
TA's Avatar
TA
Its very simple. I used a jigsaw to cut the center out, then a file to smooth the edges, followed by a coat of gloos black.
Old Feb 20, 2003 | 05:40 PM
vader86's Avatar
vader86
Default Re: open air lid (TA)
Just take a pair of tin snips or a dremel and cut a big hole in it, thats all you do.
Old Feb 20, 2003 | 06:27 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: open air lid (vader86)
Or buy a Chome replacement kit and save the original. Looks better too.
:cheers:
Old Feb 21, 2003 | 04:49 AM
Hawaiian Punch's Avatar
Hawaiian Punch
Heres a picture of mine cut out.
:thumbs:
Old Feb 21, 2003 | 08:04 AM
korvettek's Avatar
korvettek
Default Re: open air lid (Hawaiian Punch)
thanks
Old Feb 21, 2003 | 12:32 PM
JDANNER's Avatar
JDANNER
It's really simple to cut out the opening like everyone said but the aftermarket corvette suppliers sell precut ones. They are a little pricey though.
Old Feb 21, 2003 | 01:42 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
that's what i did....
Old Feb 21, 2003 | 02:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: open air lid (JDANNER)
You can get a stock one for less than $40 and cut it yourself, or pay $50 for a precut one.
Old Feb 21, 2003 | 03:38 PM
Lord Odin's Avatar
Lord Odin
Default Re: open air lid (Mr Mojo)
If I were you, I'd just get a precut one. You'll know it'll be done right and look good. Besides, what's an extra $10 compared to the rest of the stuff we pay for our cars? :smash:
Old Feb 21, 2003 | 04:33 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: open air lid (Lord Odin)
Hey guys,
Iv'e been thinking about cutting mine as well (or getting a used one from a salvage yard and cutting it). Does anyone find it an issue in the rain at all? Not that I drive the car in the rain much, but it's unavoidable in some instances. The last thing I want is for the motor to injest any water - I've had enough problems with this thing as it is!
Thanks.
Old Feb 21, 2003 | 05:53 PM
hngacurv's Avatar
hngacurv
Default Re: open air lid (TheCorvetteKid)
You aren't going to have any problem. As long as the road isn't a sheet of ice I'll drive mine in any weather and the open lid isn't even an issue.
Old Feb 21, 2003 | 06:08 PM
Lone Ranger's Avatar
Lone Ranger
I have two cut lids. One is the common variety where the baffles are cut out and the hood has been removed leaving it wide open and able to draw some bumper-cavity air (which is semi-cold air) with engine compartment air. The other one just has the baffles cut out and the hood was left intact, so that it can only draw engine compartment air.
It may run counter to all logic but my car seems to run better with the second one, which has the hood intact on it and just the baffles cut out.
[Modified by Lone Ranger, 5:08 PM 2/21/2003]
To open air lid
