Low transmission fluid
Old Feb 25, 2026 | 12:45 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Low transmission fluid
Do you think I can drive my 85 4+3 Doug Nash Overdrive about 10 miles with the overdrive switch turned off because it will be about 1/2 quart low of fluid since I just put in an all-aluminum radiator? The cooler in the new tank is empty because it's brand new. Will it be safe to drive it that far while low on ATF fluid so I can get the overdrive serviced and completely filled to the radiator ATF cooling tank?
Old Feb 25, 2026 | 02:54 PM
standswithabeer's Avatar
standswithabeer
curious as to why can't it filled where it is? will the trans will be operating for 10 miles without an oil cooler, is that right? it's a 40 year-old car, I wouldn't.
Old Feb 25, 2026 | 05:22 PM
2011KLR's Avatar
2011KLR
Remember the oil is also a coolant for the gears and the pump itself. The pump will be 'running' the entire time so heat in it is a concern.
My theory would be that since you're not going to let the OD engage, you may be OK. But the parts for a 4+3 are hard to come by.
PM me if/when you need a new pump for one
Old Feb 26, 2026 | 12:34 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
hey, if u cant jack the car, u have another option.
up at the front, passenger side, on the radiator, below the rad cap, is the sending and return libe for the OD unit. I cant remember which line is which. but i pull the rubber off the metal tube and inject a half litre of dino atf every time i do a 4+3.
i use a big syringe i got from amazon. if u could find atf in the lucas type bottles or bags with the tips u could inject that way too
Old Feb 27, 2026 | 11:18 PM
jv9999's Avatar
jv9999
I think it will be fine for 10 miles. If the fluid is too low you probably wouldn't be going anywhere as it would be below the pickup (OD or not).
Old Feb 27, 2026 | 11:25 PM
VikingTrad3r
Oil Producer
it will definitely drive. My very first 4+3 had an empty oil pan when I drove it home. I filled it up. Flushed it a couple times and that became my first track car.
Old Feb 28, 2026 | 08:07 PM
FOURSPEEDVETTE
UPDATE! I just drove it around the streets where I live. About 3-4 miles. The 4-speed manual transmission shifted perfectly, and the OVERDRIVE ENGAGED dash light and transmission also worked fine. Nothing strange. I asked my mechanic and he felt it would be fine if I just drive it normally to his shop 10 miles away. I won't use the Overdrive to go there. Going to get a new fluid and filter (screen) service done. BTW....I sent the Chinese eBay all aluminum radiator back. It leaked like CRAZY! I put a completely stock one back in. NO LEAKS!
Old Feb 28, 2026 | 08:15 PM
FOURSPEEDVETTE
Hey VikingTrad3r ..... I thought about doing that. I was worried about overfilling the system. That could be worse than being low on fluid.
To Low transmission fluid
