Brake problems.
Old Mar 22, 2026 | 04:38 AM
leonel1005's Avatar
leonel1005
Cruising
Default Brake problems.
Brakes go all the way down but they still break slightly. Inconsistent braking tho. Sometimes rock hard sometimes all the way down. Sorta. Spongey I guess? Anyway I have a new master cylinder installed and the brake fluid looks clean… did the brake guy just… not remove the air from the brake lines? Idk. 87 C4
Old Mar 22, 2026 | 05:57 AM
Whaleman's Avatar
Whaleman
If it air in the system it does not sometimes become “rock hard”. The air is always there. Dan
Old Mar 22, 2026 | 07:21 AM
leonel1005's Avatar
leonel1005
Cruising
Originally Posted by Whaleman;[url=tel:1609523827
1609523827[/url]]If it air in the system it does not sometimes become “rock hard”. The air is always there. Dan
any ideas what it could be?
Old Mar 22, 2026 | 10:50 AM
pltmgr's Avatar
pltmgr
How old are the flexible brake lines?
Old Mar 22, 2026 | 11:08 AM
81c3's Avatar
81c3
You need to be more descriptive with your issue if you want more help. When did all this start? Were there Brake repairs just completed? Brake guy??? Who would that be? Just off the cuff, Id say it almost sounds like you have a couple of issues. Soft spongy pedal is usually air in the system... Rock Hard,... that can be brake booster related. And absolutely change your flexible brake lines... your rubber lines are potentially 39 years old.....which Id almost bet are older than you... At his point in the life of a C4, replacement of flexible brake lines should be considered part of the brake job.
Old Mar 22, 2026 | 11:31 AM
range96's Avatar
range96
Old brake line do not make spongy brakes that the pedal goes to the floor. Either air in the system or leaking MC (internally) or leaking calipers. Brake booster, MC is where I would look for problems if the system is fully bleed. If you have ABS, the controller could pump the system up even though it's not fully bleed.
Old Mar 22, 2026 | 02:02 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Just throwing this out there, but it took me three new master cylinders before I actually got a good one.
Parts like that are garbage right out of the box mre often than not these days.
Placing that aside, maybe find some gravel and work the ABS on it for a bit and then come home and bleed again.
Don't need to race around doing it, just enough to work the ABS on the gravel.
Bleeding these brakes are a chore because you have to do it a half dozen times or so all the way around to get a decent pedal. In my own experience anyway.
Old Mar 22, 2026 | 08:42 PM
leonel1005's Avatar
leonel1005
Cruising
Originally Posted by pltmgr;[url=tel:1609524235
1609524235[/url]]How old are the flexible brake lines?
old but there’s no leak. No fluid on any of the brakes
Old Mar 22, 2026 | 08:46 PM
leonel1005's Avatar
leonel1005
Cruising
couple months back it started. Started as a loss of brakes on the highway on a hot day (where I live it’s consistently above the 100s F so that makes sense) brakes went to the floor but had very little at the end so I was able to make a stop. Local mechanic replaced my master cylinder a month after (sat for a while I’m a student with a part time job so I have to save for every part). After the master cylinder replacement the all the way to the floor and spongeyness went from just when I drove it for a while to all the time. No clue what a brake booster is I don’t know **** about cars that’s why im here in fact! And the flexible brake lines are the ones that go directly into the caliper right? The short ones? Not the ones that span the car length
Old Mar 22, 2026 | 08:49 PM
leonel1005's Avatar
leonel1005
Cruising
master cylinder was replaced and there’s no visible leaks anywhere on the car. I know the old master cylinder did leak due to dried brake fluid on my coolant fan relay. But it doesn’t anymore after a test. What is the brake booster, how do I test abs? And I will do a brake bleed soon…
Old Mar 23, 2026 | 09:37 AM
2011KLR's Avatar
2011KLR
You have another thread on an overheat situation. Does the 'spongey' 'all the way to the floor' correspond to when the engine overheated? The left side headers are close to the brake lines heat affects them.
Old Mar 23, 2026 | 09:40 AM
leonel1005's Avatar
leonel1005
Cruising
no, the two issues are unrelated (in my eyes at least). The overheating is a new development (to my dismay) while the brakes have been like this a couple months now (due to my inaction)
Old Mar 23, 2026 | 01:30 PM
range96's Avatar
range96
Yes.
Take the car back to the mechanic who replaced the master cylinder and ask for a working one. Should be under warranty.
Old Mar 24, 2026 | 06:55 PM
Natty C's Avatar
Natty C
You're gonna learn more on here than you're ever gonna learn from a ''mechanic'' at some shop, so long as you're interested in all of that money you're gonna save doing your own work. And most folks will take the time to walk you through things if needed.
Most folks on here won't even let a ''mechanic'' touch their Corvette unless it's something more involved like transmission work or something like that. And there's a reason for that...
Old Mar 24, 2026 | 07:05 PM
Whaleman's Avatar
Whaleman
My money is on internal leakage inside the master cylinder. Not many other problems, like you describe, have a different answer. Dan
Old Apr 7, 2026 | 10:27 AM
c4xlr8n's Avatar
c4xlr8n
4th Gear
Same problem on my 87. Definitely related to air temperature. No issues until the outside temps get up to 95 or so. When it happens the master cylinder is burn-your-fingers hot. I see the response that the brake lines are close to the exhaust manifold, but the brake lines were close to the exhaust manifold when these cars were new, too.
To Brake problems.
