Anti-lock Alert??
Old Feb 21, 2003 | 07:34 PM
joseph p's Avatar
joseph p
Default Anti-lock Alert??
Just came back from 400+ mile trip with my '89 coupe, hit two potholes on last few miles and after second one the "anti lock" indicator came on....Any ideas where to go from here??
Old Feb 21, 2003 | 11:13 PM
Rick93Z07's Avatar
Rick93Z07
Default Re: Anti-lock Alert?? (joseph p)
Check your brake fluid level, it may be marginal. The Corvette alarming on the traction control and ABS and brake fluid level is sort of "Polish". Low fluid sensor will disable both the ABS and antislip systems.
Old Feb 22, 2003 | 08:56 PM
joseph p's Avatar
joseph p
Default Re: Anti-lock Alert?? (Rick93Z07)
Fluid was fine...any other suggestions?????
Old Feb 22, 2003 | 09:08 PM
Lord Odin's Avatar
Lord Odin
Black electrical tape. Just cut off a small piece and put it over the light. :lol:
Sorry, don't have a clue.
Old Feb 23, 2003 | 03:56 PM
BBA's Avatar
BBA
If the car bottomed out, it could have damaged the wheel sensor wires, or a sensor could have gone bad, or the wheel bearings could have been loose enough to let the sensor stator flex into and destroy the speed sensor.
I would inspect the wheel speed sensors, the fronts are easier to get to than the backs, but it's still not a big problem removing them for inspection.
Old Feb 23, 2003 | 04:14 PM
torchred89's Avatar
torchred89
Default Re: Anti-lock Alert?? (BBA)
My 89 did the same thing on the Skyline drive trip. I pulled off on to the grass at the the Restaurant and the light came on. If you can't tell wich wheel sensor it is they are only 50$ dollars each and all four are different, start with the front Good luck it worked for me
Old Feb 23, 2003 | 10:23 PM
dizwiz24's Avatar
dizwiz24
This is your problem I almost guarantee it.
This happened to me. ABS light would come on over potholes compromising my braking on dry, perfect pavement causing a scare. Sometimes ABS would come on under normal braking, causing a scare since it took a longer distance than you are used to stop due to the ABS system working.
Turned out the rear ABS wheel speed sensors. I removed them and they had a few mm of brake rotor metal filings, and road grime sticking to the magnetic surface.
I used a wire brush to clean them and this fixed the ABS problem.
The front wheel speed sensors (At least on the 93, I think its different though on other years though) are totally enclosed in a hub/bearing assembly so I couldnt check those, but just cleaning the rears solved my problems.
To Anti-lock Alert??
