half dead bose
Old Feb 23, 2003 | 02:46 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default half dead bose
Radio has power, changes stations, cd works, but no sound out of any speaker. I heard that there is a relay for the bose amp, does anybody know its location [IMG][/IMG]
Old Feb 23, 2003 | 04:56 PM
bogus's Avatar
bogus
Default Re: half dead bose (zaragoza)
not off hand...
however, you would be better off asking this question in Audio/Electronics under General Corvette Topics.
Old Feb 23, 2003 | 05:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The relay is located behind the passenger dash panel. It is mounted to the left side of the dash support brace with two 7 mm. screws. I got to mine by removing my aftermarket dash panel,the stock pad may be more difficult. You may be able to get at it from below, but may be very difficult to unscrew. There are 3 or 4 wires,pink,black,orange,and maybe a pink/black. My memory short, Good Luck!!
Old Feb 23, 2003 | 11:17 PM
Mrcorvette91's Avatar
Mrcorvette91
Default Re: half dead bose (dankai)
The first thing to check is the courtesy light fuse, the radio amps are connected with it.I have had this problem 2 different times...Good luck!!! :chevy
To half dead bose
