How easy is it to replace the rear hatch.......
Old Feb 22, 2003 | 08:48 AM
69mako's Avatar
69mako
Default How easy is it to replace the rear hatch.......
window gasket??? Mine is now due for replacement.....it looks pretty straight forward. Anyone have a few cool tips?
Thanks, Larry :steering:
Old Feb 22, 2003 | 07:30 PM
tkrussell's Avatar
tkrussell
Default Re: How easy is it to replace the rear hatch....... (69mako)
See the other recent thread in this section.
You can use a flat screwdriver on the retaining spring to help pop off the hatch struts.
Even if you are meticulous with the cleanup of the old grease, it will take you under an hour for the full job.
