Stock exhaust size
Old Feb 22, 2003 | 02:41 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Stock exhaust size
Is there a differene between the tubing size in an LT-1 vs. and LT-4. I am looking for an exhaust for my LT-4 and want to make sure there is not problem if I were to buy mufflers from and LT-1 owner or from a company offering kits for LT-1.
Old Feb 22, 2003 | 03:27 PM
silver & red CE's Avatar
silver & red CE
Default Re: Stock exhaust size (LT-4 CE)
LT1 and LT4 exhaust systems are the same size, the only difference between them is that the LT4 system has a cross over pipe by the resonator (as do some late 95 6 speed LT1 systems).
Eric
Old Feb 22, 2003 | 03:48 PM
LT-4 CE's Avatar
LT-4 CE
Thanks!
I imagine your car is quite a bit quicker with the mods you have made.
Old Feb 22, 2003 | 08:34 PM
silver & red CE
If it isn't, it will be after I install my long tube headers and HOT cam :blueangel:
Eric
Old Feb 22, 2003 | 09:36 PM
LT4BUD's Avatar
LT4BUD
Default Re: Stock exhaust size (silver & red CE)
Not 100% sure of this, but also the LT4 has an Oxygen sensor on the exhaust which I believe is not used on the LT1. It threads into a "boss" on the exhaust pipe which is not provided on LT1 systems.
Old Feb 24, 2003 | 01:52 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:withstupid:
Old Feb 24, 2003 | 04:36 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: Stock exhaust size (LT4BUD)
All the '96's have the post cat O2 sensors. It's an OBDII requirement. The stock exhaust size is pretty beefy at 2.75".
Old Feb 24, 2003 | 05:40 PM
lead_foot's Avatar
lead_foot
Default Re: Stock exhaust size (Dan Parker '96)
Was it only the LT4s that had the 2 3/4 exhaust or all 1996s? :)
Old Feb 25, 2003 | 05:31 AM
silver & red CE
Default Re: Stock exhaust size (lead_foot)
All LT1/4 had the 2.75" OD, 2.5" ID exhaust system that necks down to almost 2.0" ID at a couple of points.
Eric
To Stock exhaust size
