How much $ to replace LT4 Intake gasket?
Old Feb 23, 2003 | 03:32 PM
Falcon's Avatar
Falcon
Default How much $ to replace LT4 Intake gasket?
Anyone know approximately what it should cost for a professional to replace the intake manifold gasket on a LT4?
Thanks in advance.
Old Feb 23, 2003 | 06:48 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: How much $ to replace LT4 Intake gasket? (Falcon)
No true idea.....just a wild guess.......$700+
That's only a guess :rolleyes:
Old Feb 23, 2003 | 07:02 PM
STL94LT1's Avatar
STL94LT1
I would guess $150/$200.
Changing intake gaskets really isn't a difficult job, you should consider doing it yourself.
Old Feb 23, 2003 | 07:23 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: How much $ to replace LT4 Intake gasket? (STL94LT1)
:iagree:
Old Feb 23, 2003 | 07:25 PM
StephensblackL98's Avatar
StephensblackL98
I don't know about an LT-4, but I asked the same question of a NAPA-affiliated repair shop for my '91 L-98. When the mechanic consulted his book, his estimate was $600. I did it myself for the cost of the parts - gaskets, and other odds and ends I wanted to replace. The total ran to about $125 - including a new torque wrench. I did it myself. As was said earlier, it really isn't that difficult if you have the proper tools. A shop manual is a big help, too.
Old Feb 23, 2003 | 07:27 PM
SouthernSon's Avatar
SouthernSon
Let's see: remove two plastic covers and lay aside, take out four fuel rail screws and pop off the injection system complete with injectors and lay aside, remove secondary air injection, unplug harness plugs and lay aside, accelerator bracket and a couple of other things, take off manifold and clean surfaces with acetone,.....reinstall. Just time consuming trying to keep everything clean but very easy to do. After reinstalling do not start engine for a couple of days to allow RTV to cure completely before hitting with hot engine oil. :)
[Modified by southern_son, 6:29 PM 2/23/2003]
Old Feb 23, 2003 | 07:29 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: How much $ to replace LT4 Intake gasket? (southern_son)
:iagree:
This is really a simple job providing you have tools and the space to do it.
Old Feb 23, 2003 | 07:32 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
based upon shop rates of 85-93 bux per hour, the shop labor + parts to replace an LT1/LT4 (In Mid Atlantic) is 385-400 bux.
Hope this helps :cheers:
Old Feb 23, 2003 | 07:44 PM
Falcon's Avatar
Falcon
Thanks for all your reponses, guys, that helps a lot.
To How much $ to replace LT4 Intake gasket?
