Just installed 50 series Flowmasters
Old Feb 24, 2003 | 02:23 AM
JayH's Avatar
JayH
Default Just installed 50 series Flowmasters
Dang. There is one hell of a resonance between 1500 and 2000 rpm's under load. I guess I'm approaching middle age as the sound is somewhat annoying, yet somehow pleasing :)
I also noticed a seat of the pants increase in torque :thumbs:
Nice, but I'm wondering if there's anything out there that'll flow as well, but sound a little quieter?
Thanks,
Jay
[Modified by JayH, 7:24 AM 2/24/2003]
Old Feb 24, 2003 | 07:00 AM
RichS's Avatar
RichS
Default Re: Just installed 50 series Flowmasters (JayH)
If you want no resonance go with a Corsa system.
Old Feb 24, 2003 | 07:15 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Jay,
Did you install just the mufflers or the cat back system? If just the mufflers, what is the part number.
I have read on the forum where the 50s are supposed to be way better than the 40s in terms of resonance. Interesting that yours are causing problems. Do you still have a resonator and cats?
Do they have the "twin D" looking tips on each side? I am looking for a system and have narrowed my choices down to the Flowmaster 50s, Magnaflow, and Corsa (hard time spending the dough for them!).
Old Feb 24, 2003 | 11:59 AM
JayH's Avatar
JayH
Default Re: Just installed 50 series Flowmasters (LT-4 CE)
Jay,
I had just the mufflers installed - sorry, don't know the part number. All I know is they are the DeltaFlow Series 50 mufflers. If the part # is on the mufflers, I can get under and take a look for you, but essentially I just told my exhaust guru what I wanted to do and he hooked me up.
He cut out the neck-down to 2 1/2 just before the muffler, widened the muffler inlet port to 2 3/4, and re-used the stock tips (which still contain a 2 1/2" restriction, but are stainless so they wouldn't open up.)
The rest of the exhaust is still completely stock.
Jay
Old Feb 24, 2003 | 12:01 PM
JayH's Avatar
JayH
Default Re: Just installed 50 series Flowmasters (RichS)
Corsa huh? Thanks :thumbs:
I used to live in Shohola and do some work out by Wilkes-Barre. Still have family in Pike county - God, I sure do miss the Poconos and Pennsyalvania sometimes...
Jay
Old Feb 24, 2003 | 12:59 PM
Ceptor's Avatar
Ceptor
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
Jay, I just put Flowmaster 50 series on my 91 L98, and I don't have any
resonance problems at all, at any speed/rpm. I'm not sure - maybe you've
hit on something here with the different engines? Be sure to double check your part numbers and let the guys know.
:seeya :steering:
Old Feb 25, 2003 | 12:50 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Default Re: Just installed 50 series Flowmasters (NC91L98)
Hey Jay, just keep the revs over 2000. Should be easy. :D
To Just installed 50 series Flowmasters
