Thermostat Question
Old Feb 26, 2003 | 08:58 PM
robparrish's Avatar
robparrish
6th Gear
Default Thermostat Question
Probably a naive question, but is there an easy way to tell what degree thermostat my 93 LT-1 has?
Old Feb 26, 2003 | 09:24 PM
vader86's Avatar
vader86
Default Re: Thermostat Question (robparrish)
It came with 180 from the factory.
But if you suspect something different, keep a close eye on your temperature gauge, my coolant goes straight to 160, then when the stat is fully open at 163F, the temp drops back down for a few minutes until the oil gets over that temperature and raises the coolant temp.
So at whatever temp your stat is, it should hold steady or drop a little when it reaches that temperature and then proceed back up.
Old Feb 26, 2003 | 11:57 PM
Alex D's Avatar
Alex D
If your digital temp gage shows around 175 to 180 F while driving, you have a 160F thermostat.......as said before, 180F are stock. In this case your dig temp gage wil show between 190 and 200+F while normal driving on the highway.....LT engines run at least 10 to 15 degres above rated thermostat temperature
To Thermostat Question
