Need help with speedometer and odometer
My mechanic said that I need to check into a speedometer shop and buy some module that I will need to have installed in order for the speedo to start working again. He mentioned something like a DRAM ? module. Anyway, I am no longer speaking to my mechanic (check this thread for more details http://forums.corvetteforum.com/zero...78004#5478004) so I am desperately seeking this module so that my speedometer and odometer can work again.
Any suggestions are greatly appreciated. Thanks in advance.
Replaced ECM/PROM, DIC and VSS on my 89. With as many other owners having the same problem someone should have a solution / fix for it. He/she would make a number of people VERY happy!
Pin C15 on the cluster grounds one side of the VSS, then D11 is the sinusoidal input frin the VSS (4000 pulses per mile).
Then the cluster outputs a signal at 1/2 frequency (2000 per mile) to the ECM from pin D12 by grounding this pin. The original ECM has this input at A10 pulled normally high (12v).
Only thing I can think is maybe the FelPro is shorting out the signal from the cluster; I would find and disconnect this wire D12 at the cluster (brown/white) or ECM harness A10 (brown).
Technically an engine management system doesn't need to know how fast you're going; original ECM only used this for torque converter lockup (1 to 4 upshift), mileage readout, and canister purge.
