ZR1 Rims
Old Mar 2, 2003 | 07:56 PM
Mark1376's Avatar
Mark1376
Default ZR1 Rims
Will 17 9.5 54 offset fit my 94?
54.5 X 4.75 is whats on the box
Thx before hand as Always
Old Mar 2, 2003 | 08:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: ZR1 Rims (Mark1376)
The one's that AFS sells are 56mm, I wouldn't think that 2mm would make much difference. For my 11" they are 50mm, the actual ZR1 11" are 36mm.
But for 9.5 all the way around, you should be fine.
Old Mar 2, 2003 | 08:06 PM
UDLUV12's Avatar
UDLUV12
Mark,
Yes, they will fit...but you'll likely see them sticking out about a 1 inch futher then your stock Vette wheels.
If I'm not mistaken, I believe the 38MM offset ZR1 wheels fall inside the wheel wells. Basically, the way your stock wheels appear now.
Old Mar 3, 2003 | 06:39 PM
Mark1376's Avatar
Mark1376
Thx all
Old Mar 3, 2003 | 06:54 PM
cactus93's Avatar
cactus93
8th Gear
I have the AFS wheel package (2x9.5 + 2x11) with the GS offset from AFS.
I can't see running the ZR1 offset 9.5's being a problem. If you were thinking of putting the 11" rims with the ZR1 offset on the rear, they will stick out. My 11's stick out a fraction, but not enough to look stupid. In fact, they make the car look really mean from the rear. There is a noticable difference in the two offset's though. (GS and ZR1)
Just my two cents.
To ZR1 Rims
