Engine bolt removal
Old Mar 2, 2003 | 10:13 PM
FSTRNU's Avatar
FSTRNU
Default Engine bolt removal
I need to remove the drivers side engine mount bolt and stack 2 washers on the head to keep the bolt from striking the header tubes. Where on the motor do I put the jack to keep it from hurting anything. I am going to be doing this in the garage(no lift this time) with teh car on jackstands. Any advice will be appreciated. Zach :cheers:
Old Mar 2, 2003 | 10:30 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Engine bolt removal (FSTRNU)
Any part of the engine casting should work. I use a piece of 2 x 4 to get a more pin-point contact area, rather than the jack pad. Don't lift from the oil pan, it could dend and cause problems with the crank clearance. :cheers:
