4/3 install Scorp
Old Mar 3, 2003 | 04:40 PM
frank moran's Avatar
frank moran
Default 4/3 install Scorp
any pointers for this one man operation with a floor jack, this trans has an unusual balance point, so before I get under there to wrestle this with one arm on the jack and one on the trans maybe some of you can share your experience.
Old Mar 3, 2003 | 05:16 PM
scorp508's Avatar
scorp508
Yes! :)
Get a peice of plywood about 1'x1' and put it on the jack. Rest the tranny on it and put some wood under the 4-speed part so that it tilts the tranny level. The overdrive oilpan otherwise tips the nose downward. Did you remove the clutch or are you installing it exactly as it came out? I needed a 2nd person one time to press the clutch in for me to get the input shaft into the pilot bearing.
Old Mar 3, 2003 | 05:36 PM
frank moran
Default Re: (scorp508)
same cluth though I did remove but realligned it with a pilot shaft,, I'll try your suggestion, the trans is a slippry devil with no traction for the jack plate. I also made a couple of pilot bolts, cut the heads off for a little extra guidance, thanks, frank
Old Mar 3, 2003 | 09:11 PM
frank moran
got in in, not that bad but alone it's a hassel, especially with out a trans jack. it's a bancing act when your alone and using a floor jack ..... thanks frank
Old Mar 3, 2003 | 09:14 PM
scorp508's Avatar
scorp508
Glad to hear it! I've wrestled with mine alone more times than I want to admit. :)
Old Mar 3, 2003 | 09:19 PM
72tccracer's Avatar
72tccracer
That trans is a lite weight compared to a 6 speed.
:hurray:
Old Mar 3, 2003 | 09:24 PM
frank moran
ps i believe I was in your hometown last week, Raynham? I was at the Chev dealer...
Old Mar 3, 2003 | 09:27 PM
scorp508's Avatar
scorp508
Whoa... yeah I live in Raynham. :) The closest chevy dealer to me is Walter Earl in Bridgewater.
Old Mar 3, 2003 | 09:40 PM
frank moran
maybe it was another town, dealer was Mastria ??? somwhere in that area...I work for GM so I see alot of dealers.
Old Mar 3, 2003 | 09:43 PM
scorp508's Avatar
scorp508
Default Re: (frank moran)
Matria is on route 44 in raynham. :) Pontiac, Buick GMC, Saturn :)
To 4/3 install Scorp
