cam changing made easy
Feb 26, 2003 | 11:56 PM
Cruise-In I Veteran
Cruise-In II Veteran
GM performance parts now has a setup like the LS-1 engines for the older engines that hold the hyd roller lifter up just by rotating the cam so you do not have to remove the intake system to change cams,just remove the front of the engine and the distributor. :chevy
Feb 27, 2003 | 02:49 AM
Re: cam changing made easy (clem zahrobsky)
Cool, I'd like to take a look at it...do you happen to know a part number?
Feb 27, 2003 | 07:25 AM
Cruise-In I Veteran
Re: cam changing made easy (Zix)
no but i will find out and post. :chevy
Feb 27, 2003 | 06:42 PM
Would like to know more about this?????
Feb 27, 2003 | 06:48 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:confused:
Mar 3, 2003 | 07:24 PM
Cruise-In I Veteran
the part # is 88958652 and you need 2 of this number. it will save a lot of extra work by not having to removing the intake system when changing cams. :chevy
[Modified by clem zahrobsky, 7:25 PM 3/3/2003]
Mar 3, 2003 | 07:27 PM
Pictures please or something.
Mar 3, 2003 | 07:44 PM
Re: cam changing made easy (scorp508)
:withstupid:
Mar 3, 2003 | 07:50 PM
Cruise-In I Veteran
i have no pictures but it is plastic pieces like used on the LS-1 engines to hold the lifters up once you spin the cam to raise the lifters.
Mar 3, 2003 | 09:14 PM
I can't find a listing under that number at gmpartsdirect.com or acdelco.com. :confused:
Mar 3, 2003 | 09:15 PM
How do you get them in there and to hold onto them?
Mar 3, 2003 | 09:29 PM
Cruise-In I Veteran
Re: (scorp508)
you have to drill and tap between each pair of lifters :chevy
Mar 3, 2003 | 09:31 PM
Cruise-In I Veteran
they are brand new,they just came out 3 weeks ago,call because they may not have made the web site yet. :chevy
Re: (clem zahrobsky)
Ok so...
You have to drill and tap between each lifter to add these things? Then you remove the rockers and when you spin the cam they will hold the lifters up or something? I thought these were like a tool. It almost sounds like a reverse valve spring mechanism to hold them up somehow. I think I'll pass. :)
Mar 3, 2003 | 09:45 PM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Hey Clem :seeya long time no see!
Mar 3, 2003 | 09:49 PM
Hard to believe.. :skep:
Mar 3, 2003 | 09:50 PM
Cruise-In I Veteran
Re: cam changing made easy (Mr Mojo)
hi mojo,i did not make it to latest cruise in because of the june 50 th deal last year at the museum and i will miss the cruise in again this year because the 2 events are too close together,but i will be there next year. :party:
