holy s h i t batman i just pulled my rad out to start putting in the new be cool rad and victor jr water pump there was debris half way up the core and i just cleaned this out two years ago and less than 8000 miles ago i suggest everybody check theres out before every season :cheers:
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: radiator debris (CORKVETTE1)
:cheers: :D :D
If I have to drive through leaves on the road, I try to count the leaves in front of me and then count the leaves behind me. The difference is in the RAD :smash:
I also try to make sure plastic bags and other debris are still on the road after I drive by
Back when my tranny cooler was installed....john panuzzo and ralph cleaned mine out. There was a bunch of crud in there. Definitely the thing to do at least once a year.
:cheers: :D :D
Are you gonna be at Carlisle?
:steering: [ I love that Lil Guy! ]
[Modified by jackdaroofer, 7:27 PM 3/3/2003]
yes ill be at carlisle and should be at cruise inn IV :cheers:
Hehe, I thought I was the only one who tried to keep track of all the leaves on the road:)
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Re: radiator debris (severe-1)
What,s the easiest way to get to the crud? (Besides being run over by your own car!)
I think there is a paper in the tech tips section on this. It isn't too bad though. You have to pull the radiator shroud and the radiator. Everybody that owns a C4 needs to do this. You will be shocked at how much stuff is in there and surprised at how much cooler the car will run afterward.
Yep....it's a bottom feeder, and sucks up debris like an Oreck on steroids. My debris included cigarette butts, a dead desecated bird, wrappers of underterminable origin, leaves, and a Wal-Mart bag. After cleaning the front of the radiator, the temps dropped by about 15 degrees. While you have it out is a good time to clean everything and repaint the shroud if it needs it.
