Pcv replacement
Old Mar 3, 2003 | 07:22 PM
davevette's Avatar
davevette
8th Gear
Default Pcv replacement
Ok, I know I'm not the smartest, but, I have spent two hours trying to find the pcv valve on my 1994 lt-1 coupe. Took rail covers off of both sides and no luck. Please help, with picture if possible. Thanks guys David :cry
Old Mar 3, 2003 | 07:29 PM
superlund's Avatar
superlund
Default Re: Pcv replacement (davevette)
It is on the drivers side, remove the engine/beauty cover & the PCV valve is located on the side of the intake manifold, it is actually stuck into a grommet in the side of the intake, it has a "U" shaped 3/8" hose running to a vacuum port directly behind it..
Old Mar 3, 2003 | 07:35 PM
davevette's Avatar
davevette
8th Gear
Default Re: Pcv replacement (superlund)
Thanks, will go out to garage after supper (wife is waiting) appreciate the help. David
Old Mar 3, 2003 | 08:45 PM
Dan Parker '96's Avatar
Dan Parker '96
One thing to check is to make sure the hose is not kinked. When I did my rebuild I found one of the rubber PCV hoses was a bit short and had cut off some valuable flow.
To Pcv replacement
