Opti-spark problem?
On the first very cold day last Fall, my 93 Vette made a clunking sound as I accelerated beyond about 30 miles per hour. It felt like the car was not getting gas, or as if the transmission could not move to the next gear... I'm not sure. I drove it home staying under 30 miles per hour, only slightly depressing the gas when necessary.
I took it out again the following weekend and let it warm up for 20 minutes before driving. The engine sounded fine this time, but the voltometer was jumping around the middle of the guage and the backlight for the speedometer was dimming at a traffic light. Also, when I turned on the headlights and the radio, the engine revved very low and I thought it would stall. I drove it about 3 miles, stopped the car, went into the store and came out. Then I started the car and drove it immediately. Again, when I accelerated over 30 miles per hour or so, it happened again. It felt and sounded like a clunking noise like it either could not get gas or could not change gears. So, I drove home under 30 and it was fine, again only depressing the gas pedal when necessary.
Now, it is still very cold. I only have the problem when it rains or after the car is warmed up. I'm wondering if condensation is accumulating on the Opti-spark and making the engine misfire. Could that be it? It ran fine all last summer.
Help
:flag
The ususal symptoms for a bad opti are erratic idle and/or missing at high RPMs. Although, these are the only symptoms the rest are too weird to describe.
Mine is a 92 LT-1 and has 50k on it. I've had it just over 3 years and it ran just fine. I started working on an oil leak in the front and one thing lead to another and I removed the Opti-Spark opened it up and :eek: . It was wet, rusty, and dirty! The seal around the cap was cracked and brittle. Thanks to the forum, I have completely changed out the ignition system. I didn't want to be like a Ford (found on road dead). If you drive in the rain or wash your engine with the mileage you say is on it...............beware.
We, at the forum, can easilly walk you through it. Just ask.
Strick :chevy
When you have this done, give the forum a post.
Glad to help as I just did all of this.
Strick
:auto:
Strick
Even given the aches, pains, and frustrations, I'd rather do it myself. BTW - if you do it yourself, and you are trying to get the elliptical knock sensor harness connector off of the knock sensor to drain the coolant from the block - carefully squeeze the major axis of the ellipse and it comes right off. See - that math degree will come in handy! (I know, conic sections probably aren't your specialty, but I couldn't relate binary or hex to the car.)
I would still check the obvious and/or easy stuff first. At least make sure the battery is healthy. I had a '97 Dakota with a dead battery that acted just like my '96 with a bad opti (wouldn't idle, could barely keep it running with throttle).
Strick
