Drill holes in thermostat??
Old Mar 6, 2003 | 06:52 PM
LT4BUD's Avatar
LT4BUD
Default Re: Drill holes in thermostat?? (black bart)
The 96 LT4 has factory bleed valves on the thermostat housing.
Old Mar 6, 2003 | 10:30 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: Drill holes in thermostat?? (LT4BUD)
So does my LT1, that bleeder is to relive the air after the thermostat opens the purpose of drilling the hole in the thermostat is to relive the air trapped under the thermostat :thumbs:
Old Mar 7, 2003 | 07:53 AM
LT4BUD's Avatar
LT4BUD
Default Re: Drill holes in thermostat?? (grapeknutz)
The bleeders are used when installing a new thermostat or when refilling coolant after draining. You open the bleeders and add coolant until coolant start flowing out of the bleeders. At first air comes out, then bubbly coolant, then solid stream of coolant. You do this before you start the engine.
I think the real purpose of drilling holes in the thermostat is to increase coolant flow as even when most thermostats open, they still restrict coolant flow to some extent.
