Simple and effective center console lid repair
I made this repair to my center console lid about six months ago and never got around to posting it. I saw a thread recently about finding replacement lids and thought I should post this.
I used weatherstrip adhesive and wrapped the lid with masking tape to hold it in place until it dried. The repair worked great, six months later it is still holding. The only thing I would have done differently is I would have put a 1' ruler or other straight edge along the side of the lid I had glued before applying the tape. That way, the edge of the lid would have been perfectly straight instead of being a little wavy. Other than that, it is good as new!
Cruise-In II Veteran
Re: Simple and effective center console lid repair (vetracer)
Ah, great minds..., nice work.
I used a similar method on mine a copla years ago and still holding; much prefered to buying a new one.
Re: Simple and effective center console lid repair (65Z01)
Ha!! I did the exact same thing two nights ago. Instead of weatherstip adhesive, I used the Dow expanding, insulating foam (the type that's water based and expands minimally, ~10%) that I bought at Lowes. Mine looks great also, I'll see how it holds up to the summer heat.
Location: 63.8% of all statistics are made up on the spot.
1 Post
St. Jude Donor '08-'10
Me too, me too. I used RTV about 1 1/2 years ago and still looking good.
Thanks for the tip, I need to do this to mine. I'll use the ruler or straight edge tip you suggested.
Not a bad idea.. I'll try it myself. Every console lid is going to be different as far as repairs. If it don't turn out the way I hope it does then i'll just buy a new one. Thanks for the tip though. :cheers:
Re: Simple and effective center console lid repair (87vette)
i thought it was for the lid button ( the thing u push back to open the lid). When the spring broke in mine i shoved crumpled bits of newspaper in the place of the little spring. Works better than the spring.! :cheers:
St. Jude Donor '06
Re: Simple and effective center console lid repair (Glasman66)
Anyone know how to fix the latch?
Glasman66, my latch broke early last year; since I couldn't find a replacement for the OEM flat spring I used RTV to pot two small coil springs in place.
Recently I noticed that MAD sells the spring for some C4 console lids; I guess timing realy does count.
1 Post
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Simple and effective center console lid repair (joecaver)
Great idea. Mine was in perfect shape, but has just recently started to catch on the hinge side and pull the cover out of place. I tried adjusting it like 3 times, but it still catches. I dont open it all the way anymore, at least not until i fix it.
I never lock mine so when my spring broke, I laid down two pieces of valcro on the base and top. work great for 3 years now. later.
