Which MSD ignition do I need?
Old Mar 6, 2003 | 05:34 PM
MagRed_04's Avatar
MagRed_04
Default Which MSD ignition do I need?
I was looking at the Digital 6 Plus, and then saw a 6A and a 6 AL, which one is the right one? :skep:
Old Mar 6, 2003 | 05:37 PM
scorp508's Avatar
scorp508
Depends on what you need it to do. The Digital 6+ has more/different features than the others.
Old Mar 6, 2003 | 05:55 PM
pablocruise's Avatar
pablocruise
Default Re: Which MSD ignition do I need? (Vette_Crazy)
Need? or want? :D :cheers:
Be aware that they only disharge those neat multiple voltage pulses no higher than around 3K RPM or so.
Still I wouldn't mind one either. I see the digital will allow you to handle cylinders individually. Nice!
Old Mar 6, 2003 | 06:24 PM
MagRed_04's Avatar
MagRed_04
Default Re: Which MSD ignition do I need? (89 Paul in Cal)
I am installing a SuperRam, Cam, & AFR heads... :hurray:
Old Mar 6, 2003 | 06:41 PM
vader86's Avatar
vader86
I plan on doing the same and will be putting in the Digital 6, it has a start retard and a rev limiter built in.
If i was using Nitrous or forced induction, i may use one of their setups specifically made for it, but the digi6 will work for those just fine.
Old Mar 6, 2003 | 06:42 PM
FSTRNU's Avatar
FSTRNU
I have a Digital 6, no really big difference little better gas mileage thats about it.
Old Mar 6, 2003 | 07:50 PM
snaketr's Avatar
snaketr
Default Re: Which MSD ignition do I need? (FSTRNU)
You said you are installing a SR, what about DFI are you planning that down the road. If so save yourself the money and get the 6A. The DFI does everything plus 100 times more than what the digital 6 will do, but if the stock ECM is your thing get the Digital6
Old Mar 7, 2003 | 08:38 PM
MagRed_04's Avatar
MagRed_04
Default Re: Which MSD ignition do I need? (snaketr)
What is DFI? :confused:
To Which MSD ignition do I need?
