Armor All on Engine Plastic
Old Mar 6, 2003 | 10:50 PM
Dark-Knight's Avatar
Dark-Knight
Default Armor All on Engine Plastic
Had a dude at oil change shop advise against using Armor All under the hood on any components, says it makes them brittle an prone to crack. I've known guys to use AA for years, never heard this before.
What have you heard? What do you use to make it shine? :grouphug:
Old Mar 6, 2003 | 11:31 PM
Rich_01659's Avatar
Rich_01659
Default Re: Armor All on Engine Plastic (Beautiful Beast)
Very few (if any) will recommend Armor All. I read a few post over the months and the concenses is that it does more harm than good.
good luck
Old Mar 6, 2003 | 11:43 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I used it before I discovered something better.
It never hurt any of my plastic. Just doesn't last long enough.
SO don't worry, if you've used it already you haven't done any damage.
Get yourself some "Back to Black".
Put it in a spray bottle and you can get it down into areas you can't reach.
Plastic and rubber stuff seems to just love it.
Another good one for plastic and rubber under the hood is Mequiars Tire Shine. It makes rubber hoses look like new AND it last a long time.
Old Mar 6, 2003 | 11:53 PM
Grouchy67's Avatar
Grouchy67
Have seen several warnings lately to be careful what you use under the hood of the newer cars. Seems like the fumes can supposedly do nasty things to your electronics. Even the newer silicone sealers are advertising "sensor safe".
Old Mar 7, 2003 | 12:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
These days I use Formula 2001 and Stoner's tire shine on plastic and rub ber parts.
Old Mar 7, 2003 | 12:08 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Armor All on Engine Plastic (65Z01)
Formula 2002 is great stuff. I forgot about that one.
It's really good on tires.
Old Mar 7, 2003 | 01:46 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I switched from AA to 2001 a while ago for the underhood stuff, I still use low gloss AA for the dash, because I haven't found anything else that is low gloss...
Old Mar 7, 2003 | 01:58 PM
Hamert's Avatar
Hamert
Default Re: Armor All on Engine Plastic (C4DC)
I use Tire Wet and Black. You can get it at WalMart. I don't know if it's bad for the plastic or not but it shines like a mother umm, errr, you know. Just be careful you don't get it on your garage floor while you're doing your tires with it or you may go for a ride on your backside. The stuff is extremely slippery.
[Modified by Hamert, 2:08 PM 3/7/2003]
Old Mar 7, 2003 | 04:58 PM
KFehling's Avatar
KFehling
Default Re: Armor All on Engine Plastic (Hamert)
I have also heard these reports on AA. I tried Meguire's Tire Shine (or whatever it is called) for a while and really liked it as it left no greasy residue and it had a nice flat black look to it--I personally don't like the wet look. Currently, I use all Griot's Garage products and their vinyl and rubber care product is fantastic. No residue, nice flat finish. Seems to last quite a while also.
Old Mar 7, 2003 | 06:45 PM
corvette-pilot's Avatar
corvette-pilot
Default Re: Armor All on Engine Plastic (lani's 93)
I have long since gone away from Armour All. These stories have gone around for years and it isn't worth it to me. So I am using up any left over stuff on my fender wells :D
Based on info gained here I bought some Aerospace 303 protectant. It isn't shinny or greasy. Go to their web site and if what they say is true it is the best stuff I have found to protect vinyl/rubber/gaskets/seals ect
To Armor All on Engine Plastic
