breaking in engine
Old Mar 8, 2003 | 09:31 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default breaking in engine
I'm going to start my engine for the first time since I had it rebuilt by a machine shop. The shop told me to use SAE 30 weight. Any suggestions before I put the oil in tomorrow. Also any tips on breaking the engine in. It's a 1986, 383 strokers, with all the bells and whistles. :steering:
Old Mar 11, 2003 | 12:52 AM
drive it's Avatar
drive it
Default Re: breaking in engine (PMARTINEZ92126)
For flat tappet cam you must run it at 2000 or so rpm for 20 minutes or so on initial start up-also I'd pre oil it.
Old Mar 11, 2003 | 01:01 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: breaking in engine (drive it)
You MUST pre-oil the engine. If you don't, you will destroy it. I fired my new engine up for the first time today, and I pre-oiled it and then ran it at 2000 rpm for 30 minutes. I preferred to do my break-in with the car up on jack-stands so that I could more easily walk around the car inspecting for leaks and drips on the ground. If you can set the timing without shutting the engine down, that's preferred during break-in.
Old Mar 11, 2003 | 01:02 AM
PMARTINEZ92126
It's a roller cam. I have disconnected the distributer and will crank the engine till I see oil coming out of the pushrods. Any more suggestions on breaking in the engine will be appreciated.
Old Mar 11, 2003 | 01:45 AM
drive it's Avatar
drive it
Long tube headers? Make a heat sheild next to the power brake booster so you don't melt a hole in it ......like I did...
Old Mar 11, 2003 | 01:54 AM
CorvetteZ51Racer
Don't do this. 1) your starter will overheat if you try to crank it long enough to properly pre-oil the motor (at least 30 seconds). 2) you'll be turning the internals of the motor before getting the oil there, which defeats the purpose. If you do it this way, you WILL damage your bearings.
You want to pull the distributor out of the motor and turn the oil pump shaft with a pre-oiling attachment on a strong power drill. You should be able to pick up a pre-oiler attachment at an autoparts store. For a Gen 1 SBC, it basically looks like the shaft of your distributor, but without the cam gear. You chuck it up in a strong power drill, and turn it (slowly at first to prime the oil pump and ensure you're fully engaged with the oil pump driveshaft, speeding up slowly as you go along) for a minimum of 30 seconds. I usually do 1 minute just to be sure. It's a good idea to have someone there to look at your gauges and make sure you are in fact getting oil pressure.
To breaking in engine
