Spark plug changes.... What is your tip
Old Mar 11, 2003 | 01:37 PM
Jimbo93's Avatar
Jimbo93
Default Re: Spark plug changes.... What is your tip (grapeknutz)
Make sure the gap is correct and use an anti-seize compound on the threads.
Old Mar 11, 2003 | 01:58 PM
wz2wj1's Avatar
wz2wj1
I have a 94 and changed mine for the first time, in about an 1 1/2 hrs. Had to remove ASR to get at plugs on drivers side. Was actually pretty easy.
:seeya
Old Mar 11, 2003 | 04:51 PM
STL94LT1's Avatar
STL94LT1
Tip: Use an open end wrench to turn the spark plug socket on #8.
Old Mar 11, 2003 | 08:31 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Are you guys changing wires at the same time?
Old Mar 11, 2003 | 10:24 PM
my350tpi's Avatar
my350tpi
Default Re: (Mr Mojo)
I'm about to do the wires, plugs, water pump and probably the opti. I don't care what it is, I give it a shot first. VERY infrequently has anyone else worked on either of my Vettes. It's mine d@#$it and I'll bleed for it! I did however, pay a trustworthy shop (business associate) to do my fuel filter ('92 LT1). After reading some of the posts here, I do believe I would take another crack at it though! Good luck with those plugs! :crazy: :crazy:
[Modified by my350tpi, 10:25 PM 3/11/2003]
Old Mar 12, 2003 | 01:00 PM
TealBlueEyes's Avatar
TealBlueEyes
Default Re: (my350tpi)
I multiply however long people on the board say it takes to do a job by 3. :D I did my plugs on my '94 for the first time last year. I was a first timer and it took about 4 hours. Last plug on passenger side is the only real pain. Make sure you have an extension and a swivel. The driver's side looked worse to me, but once you move the ASR unit out of the way, it's not too bad.
You can certainly do it if you want to, but be prepared to spend a little time snarling at it.
[Modified by TealBlueEyes, 1:01 PM 3/12/2003]
Old Mar 22, 2003 | 12:16 PM
FELNGR8's Avatar
FELNGR8
Default Re: Spark plug changes.... What is your tip (Mervz)
Zane, that's what many have told me, I haven't attempted it yet, so I don't know. The way I work, it will take 8 days :eek:
I'm not rolling my eyes at you Frank. I just can't believe it would take anyone that long :lol:
I'm sitting here taking a lunch break. I just did the four driver side plugs in 2 hours including a trip to Autozone for anti-seize. First time for me. I didn't take off the wheel and wish I had.
Now I'm really looking forward to the passenger side. Yeah right.
Then I tackle changing out the wires. It might be a 6-8 hour job by the time I'm done. But I am BONDING with my Vette.
I can do it. I can do it.
[Modified by 94lt1torchred, 11:19 AM 3/22/2003]
Later
Yeah, sure I can do it. I got number 8 on and torqued and could not get the spark plug wrench off the plug. I had to take it back out. take off the plug wrench, and put it back in withn the plug wrench loosely on. But I got it and torqued them all. 3.5 hours.
Then I do the passenger side plug wires, no sweat. Then I start looking at how in the hail I'm going to get to the opti for the other wires. Decide to put back on the original wires and go for a ride. It runs beautiful, my high rev miss is gone. and I love her again.
Enough work for one day.
[Modified by 94lt1torchred, 4:49 PM 3/22/2003]
Old Mar 22, 2003 | 05:15 PM
Steel Blue 91's Avatar
Steel Blue 91
For me it's a three beer job.
Remove inner fenders, wires. looms and plugs. Beer while gapping plugs, applying dielectric grease to top of the plugs and antisiese to the threads. I install the plugs on the PS of my L98 because it is a real beatch. Beer while I apply neosporen to all thre little cuts on my hands and fingers. Install DS plugs, attach wires and looms, install the fenders and reattach all other equipment. Cross fingers, start engine. Beer while listening to the engine purr. All totaled, about an hour and a half.
Old Mar 22, 2003 | 05:54 PM
FELNGR8's Avatar
FELNGR8
Default Re: Spark plug changes.... What is your tip (94lt1torchred)
And besides I almost got my arm caught between the engine and frame. While I was fussing with number 6 plug my arm swelled up and I was caught liike a monkey with his hand in a cookie jar. I was in a panic for a while because i could not pull my arm back out.
Keep a cell phone on your belt so you can call 911 if you get caught.
