front outer tie rod end
Old Mar 11, 2003 | 11:17 AM
jtfrog's Avatar
jtfrog
Default front outer tie rod end
ijust recieved my tie rod ends for my 86. I noticed that they dont have a grease fitting, there doesnt appear to have a spot for one, any ideas
Old Mar 11, 2003 | 01:23 PM
c4cruiser's Avatar
c4cruiser
Default Re: front outer tie rod end (jtfrog)
Who made them and where did they come from?? GM? Moog? TRW? WongFu Industries? Front tie rod ends should always have a zerk fitting.
Some tie rod ends may have a plastic plug pushed into the hole and you would have to pop it out and install the proper fitting.
Old Mar 11, 2003 | 01:48 PM
don hall's Avatar
don hall
You may have the polygraphite type tie rod end where the lubrication is impregnated into the surface of the metal. Here is a link on this type of tie rod:
http://www.p-s-t.com/fekgmpg.html
Old Mar 11, 2003 | 02:29 PM
jtfrog's Avatar
jtfrog
i got them at The last detail corvette for 31.00 The box they came in say ac delco
Old Mar 11, 2003 | 03:06 PM
JasonL's Avatar
JasonL
Default Re: front outer tie rod end (c4cruiser)
Actually GM didn't use zerks on tie-rods on the later C4s. On my '96, the only zerks on the car are the front ball joints.
Old Mar 11, 2003 | 03:37 PM
jtfrog's Avatar
jtfrog
Default Re: front outer tie rod end (JasonL)
Box says AC Delco
Old Mar 11, 2003 | 04:20 PM
c4cruiser's Avatar
c4cruiser
My 92 has them and they are the original ones. Any idea when they changed??
Old Mar 11, 2003 | 05:03 PM
JasonL's Avatar
JasonL
Not sure when they changed, but that seems to be the trend these days. Kind of like sealed wheel bearings I suppose :)
To front outer tie rod end
