LT4 hotcam, grind number?
Old Mar 11, 2003 | 09:52 PM
MongooseLT4's Avatar
MongooseLT4
Default LT4 hotcam, grind number?
I'm getting ready to install a hotcam tomarrow, but I want to make sure the cam i bought used is actaully what I think it is. On the end of the cam it has these numbers....
338 97R
586 WB83
Can someone please tell me if this is the LT4 hotcam or not....thanks :cheers:
Old Mar 11, 2003 | 10:48 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: LT4 hotcam, grind number? (MongooseLT4)
It should have some yellow paint on one end as well.
This pic should show what I mean... (click for larger image)
[Modified by Dan Parker '96, 9:49 PM 3/11/2003]
Old Mar 12, 2003 | 12:41 AM
MongooseLT4
Default Re: LT4 hotcam, grind number? (Dan Parker '96)
well it is used so its not going to look like that.....Do you know if the grind number is right?
Old Mar 12, 2003 | 12:43 AM
Dan Parker '96
The paint should still be visible. My 100K LT1 cam still showed red.
Old Mar 12, 2003 | 12:58 AM
MongooseLT4
yes it does have paint on it, however the cam is at a buddies house and I don'nt remember what color it is
Old Mar 12, 2003 | 12:19 PM
MongooseLT4
Ok I figured out how to tell if you don't have the cam card......
24502586 This is the GM part number for the LT4 Hotcam, the last three numbers are the same as the first 3 numbers on the second line in the grind number. :cheers:
To LT4 hotcam, grind number?
