Cold start problem?
Old Mar 12, 2003 | 10:10 PM
Anotheredvette's Avatar
Anotheredvette
6th Gear
Default Cold start problem?
On an initial start, I have to crank the engine at least 3-4 seconds before it will start. Once it is started it runs fine and starts on the first crank all day, but once the car sits for around 3hours or more,the problem returns. I changed the fuel pump,filter,regulator, injectors are only 3yrs old,egr was also changed. It is an 89 coupe, all stock (this model does not have the cold start injector) Can anyone help diagnose this annoying problem? :auto: :auto:
Old Mar 12, 2003 | 11:17 PM
jfb's Avatar
jfb
Default Re: Cold start problem? (Anotheredvette)
3 year old injectors or not, put a fuel pressure gauge on your fuel rail shraeder valve, turn on the igition for longer than 2 seconds and turn it off. GM says you shouldn't lose more than 1 psi in 30 minutes or you have leaky injectors. Leaky injectors can cause hard starting.
Old Mar 14, 2003 | 09:09 PM
Anotheredvette
6th Gear
Default Re: Cold start problem? (jfb)
Thanks for the advice, I put the pressure gauge on and watched the pressure drop from 32-22 in 3min!! after another 1/2hr, it was down to 16lbs!. There are no visible leaks anywhere near the fuel rails etc. Is this a telltale sign of leaking injectors?, if so, is there any way of finding out which ones are bad, other than pulling the plugs and looking for the fouled ones? :confused: :auto:
Old Mar 14, 2003 | 10:18 PM
vader86's Avatar
vader86
Your injectors are shot, replace them ALL. If one goes bad, the rest are sure to follow.
Try the Ford SVO #24s
Old Mar 14, 2003 | 11:05 PM
Anotheredvette
6th Gear
Default Re: Bad injectors
Vader, you recommend Ford SVO #24s, Can I get them online for a decent price? What can I do to prevent this from happening again? like I said they were only 3yrs old. Could lack of use in the winter have an effect?, the car is stored outside under a cover during the winter months.
Old Mar 15, 2003 | 10:24 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Bad injectors (Anotheredvette)
Vader,
How can you be so sure it is leaking injectors just from Anotheredvette's post? Injectors are of course, a possibility, but so is a bad check valve or regulator. As jfb is so adamant about encouraging, and I agree completely, you have to eliminate the possibilities before jumping to any conclusions. Without pinching off the fuel supply hose, you don't know if the check valve is allowing fuel to drain back to the tank. Without pinching off the fuel return hose, you can't be sure that the regulator isn't responsible.
Old Mar 15, 2003 | 07:59 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Bad injectors (Ray Quayle)
Vader,
:iagree: :yesnod:
To Cold start problem?
