Timing on 87
Old Mar 12, 2003 | 10:22 PM
tophorse's Avatar
tophorse
Default Timing on 87
One of my friend want to lend me his timing light. Could anyone tell me how to use them? (i.e. when we adjust the distributor do we just rotate the distributor cap or we have actually unscrew the hold down clamp and rotate the distributor shaft. By the way my car start ok now. I just want to make sure the timing is ok). I have an 87 vette. What is correct setting for my 87? Thanks
Old Mar 12, 2003 | 10:27 PM
scorp508's Avatar
scorp508
Default Re: Timing on 87 (tophorse)
Stock timing setting is 6* BTDC for '87. When you loosen the holddown clamp on the distributor your twist the distributor cap.
Old Mar 12, 2003 | 11:02 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Timing on 87 (scorp508)
you have to unplug the computer first :cheers:
Old Mar 12, 2003 | 11:07 PM
severe-1's Avatar
severe-1
Make sure you find the timming mark on your balancer before you even start. You may want to mark it with yellow crayon so you can see it easier.
To Timing on 87
