wire for power antenna?
Old Mar 13, 2003 | 09:18 AM
apollo30346's Avatar
apollo30346
Default wire for power antenna?
I want to be able to keep the antenna from going up while I am playing CD's... I have all aftermarket equipment.... so I need to make sure my amps still come on... I have the car all apart now, so would like to go ahead and put the toggle switch in .... Anyone know which wire it is to split???? I have a 1988....
thanks
Old Mar 13, 2003 | 09:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: wire for power antenna? (apollo30346)
I plan to do the same to mine. Its the pink wire on my Delco/Bose. Have you looked at the back of your stereo. They may have tagged the leads with the info your looking for. The relay is behind the middle piece of trim around the top of the cargo area. You could tie into the relay there if you can't trace it to your dash area. Good Luck!! :cheers:
Old Mar 13, 2003 | 10:17 AM
apollo30346
Default Re: wire for power antenna? (AGENT 86)
Thanks Agent,
I thought it was the the pink one, but I just want to be sure that it does not my amps from turning on when the antenna is in the down position....Do you know if that is the case with the pink wire?
Old Mar 14, 2003 | 12:46 AM
AGENT 86's Avatar
AGENT 86
I cant be sure until i pop mine ouy again to do that switch thing. Is yours the bose or aftermarket. Jimswhite92 has all the wiring info.Give him a ring and he'll set you straight. Good Luck!! :cheers:
Old Mar 14, 2003 | 12:55 AM
84FromHell's Avatar
84FromHell
Your aftermarket stereo should have the wires labled and it'll will tell you in the owner's manual (of the stereo) which wire is the power antenna. I think it's blue (standard) but not sure. Just put an interupter switch inline. I used a small rocker switch and it's hidden in the pocket I installed under the HU. You can't even see it :cool:
Old Mar 15, 2003 | 01:58 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
The power antenna wire and remote turn on wire (turns on your amps) are two separate wires. The aftermarket harness will have each lead. Blue with white stripe for antenna and blue for remote turn on. The factory harness will have it pink but you shouldn't be cutting into your factory harness. You are using an aftermarket harness right? The antenna should only come up when the radio is on and go down when the CD is playing. You don't have to install an external switch to do it manually unless your stock harness has been chopped into. :skep:
To wire for power antenna?
