[Tech Question] {Horn}
Old Mar 13, 2003 | 12:03 PM
J Z06's Avatar
J Z06
Default [Tech Question] {Horn}
Seing I am not alone on this subject...I have a sometimes functional horn,and sometimes not. If you turn the wheel, they'll work...and they work fine with the vats. Has anyone come up with a solution to the contact trouble? Could you make a remote switch or purchase new buttons from somewhere? I needed mine last night and thank God it worked...:)
Old Mar 13, 2003 | 12:30 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Default Re: [Tech Question] {Horn} (JD 90 383)
Try this link, it may be of some help:
http://forums.corvetteforum.com/zerothread?id=506136
Going beyond what I have written, I have heard of the contacts inside the steering hub going bad. I believe I was told that to access them required dismantling/pulling the hub. Never had to go that far myself. Looking at the parts blowup in the GM Y car parts manual nothing is shown on how the assembly is put together and what is in there.
Old Mar 14, 2003 | 02:15 AM
65Z01's Avatar
65Z01
JD, I had a general contact problem where the button touched the sides but I think your air bag complicates things beyond my simple fix.
Anyway my malfunction wasn't position dependent so sounds like it was different from yours.
To [Tech Question] {Horn}
