Bushing help
Old Mar 13, 2003 | 07:18 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Bushing help
whats the best way to put these in my strur rods and control rods ??? help me thanks JAY :steering:
[Modified by jparr, 6:18 PM 3/13/2003]
Old Mar 13, 2003 | 09:53 PM
pablocruise's Avatar
pablocruise
Default Re: Bushing help (jparr)
what kind? stock replacements or aftermarket poly's?
(my polys were 2 piece that you sandwhich in and then insert a metal sleeve)
Old Mar 14, 2003 | 10:32 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Bushing help (89 Paul in Cal)
I don't know if OEM replacement bushes are available Paul. I stand open to correction on that.
Doing a poly install should be pretty easy, like 89 Paul said, they come in two pieces, you just lube them up with the provided lube, slide the metal sleeve in between the two halves and re-install the suspension parts. Hardest part is getting the parts off and removing the old bushes.
Old Mar 14, 2003 | 02:44 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Re: Bushing help (Red 90 L98 Coupe)
i have poly from vette brakes,they do split in to 2 peices thanks for the help jay :cheers:
To Bushing help
