Timken hubs
Old Mar 14, 2003 | 10:26 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Timken hubs
Anyone have any experience with these hubs? I can get them (both front and rear) at my local auto parts store for pretty cheap. They come with a one year warranty.
Old Mar 14, 2003 | 03:17 PM
jimswhite92's Avatar
jimswhite92
Default Re: Timken hubs (Steel Blue 91)
See attached thread ....
hrocks seems to have good info on timken. I have used timken on other applications and they are a premier bearing.
http://forums.corvetteforum.com/zerothread?id=167789
Old Mar 14, 2003 | 05:10 PM
Steel Blue 91
Default Re: Timken hubs (jimswhite92)
Thanks for the link. I may have to order the one I need and a few spares.
Old Mar 14, 2003 | 06:22 PM
1991Z07's Avatar
1991Z07
All I can say is that I went through a rear set of Timkens in less than 2 years.
My ACDelco bearings worked fine for 9 years. When I replaced them about a month ago I went with Delco's.
I don't know why they went bad, they just did.
Old Mar 15, 2003 | 10:33 AM
h rocks's Avatar
h rocks
I should mention that Timken does not manufacture ball bearings, only roller and tapered roller bearings. So if they are being sold as "Timken" bearings, they must be outsourced to another bearing Mfr. and packaged as Timken.
(C4's are obviously ball bearing hubs. If they were rollers, they would last MUCH longer. If they were re-packable rollers, they would last dang near forever!)
Old Mar 15, 2003 | 10:44 AM
Steel Blue 91
Default Re: Timken hubs (h rocks)
If only the hubs were a serviceable part. There was a thread a while ago about trying to rebuild the hubs. Don't remember what the last word was on that process.
Old Mar 15, 2003 | 12:24 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
WTF are you smoking? :lol:
My brother works for Timkin, and last time he checked they made ball bearings ALL THE TIME. :D
Old Mar 15, 2003 | 03:38 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Timken hubs (Mervz)
If your brother told you Timkin makes ball bearings...What is HE smoking?
Last time I had to replace the "bicycle" bearing rear hubs on my car, I took an assembly apart to see if it couldn't be machined to take a tapered roller bearing. I couldn't find anything in the bearing spec book that could be stuffed into a modified housing. Hopfully, someone else has been more successful than I was?
RACE ON!!!
To Timken hubs
