fog light adjustment
Old Mar 14, 2003 | 08:20 PM
hz900's Avatar
hz900
Default fog light adjustment
How do you adjust the fog lights aim up and down on an 86? I did a search but the only thing I found wasn't helpful. Thanks.
Old Mar 15, 2003 | 05:56 AM
hz900's Avatar
hz900
Default Re: fog light adjustment (hz900)
I know someone has done this????
Old Mar 15, 2003 | 06:34 AM
beachcat's Avatar
beachcat
I didn't know this could be done. :confused: :lurk:
Old Mar 15, 2003 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sit on the hood to lower,sit on the rear to raise. Other than that i think your out of luck!! :cheers:
Old Mar 15, 2003 | 08:59 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: fog light adjustment (beachcat)
:iagree: but I'll hang around to see if anyone has done it :lurk:
Old Mar 15, 2003 | 09:39 AM
vanduker's Avatar
vanduker
Default Re: fog light adjustment (Steel Blue 91)
I'm not sure on the earlier cars but on the 96 there is an adjustment screw just below the bottom center of the lens. Adjusts up and down but not side to side.
Mark
Old Mar 15, 2003 | 10:05 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I may do some photos for you for this to make sense. The plastic stalk that you remove to change the bulb, goes into a plastic cylinder. This plastic cylinder will unscrew and can then be swiveled up, down, left or right. You then screw the cylinder back down. Does this make any sense? It's much easer to show then describe.
To fog light adjustment
