Anybody replace spindle seal when replacing hub bearings
Old Mar 15, 2003 | 10:12 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Default Anybody replace spindle seal when replacing hub bearings
I am in the middle of that horrid ordeal replacing the rear hub bearings in combination with re-doing front and rear brakes. Car has 96k miles and brakes have never been changed. In fact they still have some good meat on the rears. I have disassembled rear suspension to get to the hub bearing Torx bolts. The spindle nut was definitely not at 151lbft as is called for in manual. Guess I'm lucky. The hub carrier has a bearing seal. Looks ok. Should I leave it or replace it? :skep: :confused: Also, any lubrication for shim that is behind bearing and rides on bearing seal?
[Modified by Dominic Sorresso, 9:13 PM 3/15/2003]
Old Mar 15, 2003 | 10:28 PM
1MoorTym's Avatar
1MoorTym
Default Re: Anybody replace spindle seal when replacing hub bearings (Dominic Sorresso)
I didn't lube that shim because its stationary against the other surfaces if I remember correctly.
