DISTRIBUTOR QUESTION 86 VETTE
Old Mar 15, 2003 | 10:52 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default DISTRIBUTOR QUESTION 86 VETTE
Two wires clips go to the distributor, one of them has a brown connector and the other one is white. They connect on the drivers side of the distributor. Is the brown clip closer to the engine or is the white clip closer to the engine, or do they only fit one way. Mine are screwed up and I can't tell anymore. :rolleyes:
Old Mar 15, 2003 | 11:04 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: DISTRIBUTOR QUESTION 86 VETTE (PMARTINEZ92126)
You distributor cap should be labeled BATT and TACH. The brown clip is the tach feed, and the white clip (with the red wire) is the battery power. If the cap isn't labeled, the battery clip attaches to the right hand of the two terminals.
Old Mar 15, 2003 | 11:21 PM
atotalnincompoop's Avatar
atotalnincompoop
I think that they will only fit one way anyways :cheers:
To DISTRIBUTOR QUESTION 86 VETTE
