Need to buy quick! Need some help though...
Old Mar 19, 2003 | 11:28 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Need to buy quick! Need some help though... (ralph)
Jesse, i have a set of 16x8 with 5.5 BS. Since you have an 89, we have the same width rear. They will be close. With an ET street, mine would stick out less than 1/2 inch.
Ralph,
I mounted them without the tire to check clearance, they are gonna be CLOSE! With the car jacked up, they are out about 1" from the fender. I think when there is a tire mounted on the wheel, and they have the weight of the car on them, they will most likely be flush. Hopefully when the car squates, the tops of the tires will tip in enough to clear. GUess we will see :D
I would guess that if your are working, mine should too. :cheers:
Old Mar 20, 2003 | 04:22 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Need to buy quick! Need some help though... (ski_dwn_it)
My God.......with everything you've done with your vette....believe me you don't need anyone's help...
I followed your build up...and all I can say is......FANTASTIC......I feel special that you are even asking us........
tony
Good Luck....
:cheers:
[Modified by oldace84, 4:27 AM 3/20/2003]
Old Mar 20, 2003 | 02:17 PM
ralph's Avatar
ralph
Default Re: Need to buy quick! Need some help though... (oldace84)
Jesse, sorry to say, but i think you would have been better off with 15x10x7.5BS
Dave, the rears changed in 88, as did the rest of the suspension. I have a complete 93 rear my 85.
[Modified by ralph, 1:19 PM 3/20/2003]
Old Mar 20, 2003 | 10:53 PM
hookedup's Avatar
hookedup
Ralph,
Do you know how much wider/narrower the early vs. late rears are?
Vic,
I emailed you, I don't have IM.
Dave
