WIerd Noise
Old Mar 16, 2003 | 02:29 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default WIerd Noise
Stop the car for driving about 40 minutes. GURGLE GURGLE GURLGE. I open the hood and look at the overflow resevoure (sp?) for the radiator...it looks as if it is boiling! This normal.............i don't remeber this happeneing last spring. (CUrrent Temp Outside 60's coolant temp was within normal range).
Any Help is great as usual. Thanks
-Will
Old Mar 16, 2003 | 03:00 PM
Siveck's Avatar
Siveck
Default Re: WIerd Noise (flyinace2000)
When this happens, I would say that either the fan is not working properly, radiator needs external cleaning, or the coolant mixture is not right. You say that the temps are in the normal operating range. I would assume that would be 180-230 for our cars. 212 is the boiling point for water. Anti-freeze/ coolant raises this boiling point. Change your anti-freeze if you haven't lately or are unsure of the mixture. It should be 50/50 distilled water/antifreeze as a general rule more or less for your region. Make sure that your fan is operating properly. make sure that there isn't any junk bllocking your radiator fins. Also, your temp sending unit for your guages could be bad. I would say to check these things out first.
Old Mar 17, 2003 | 10:47 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: WIerd Noise (Siveck)
Sounds like it may (and I repeat, may) be time to look into head gaskets. Start with the cooling system checks first and move on from there.
Old Mar 17, 2003 | 12:06 PM
John Row's Avatar
John Row
If it is normally running below 212 then boils off after you shutdown, check the expansion tank pressure cap (used to be called the radiator cap, but now it's 3' away from the radiator). I think they're supposed to hold 14 or 15 lbs. This will keep the coolant from boiling to about 260 degrees.
Old Mar 17, 2003 | 08:19 PM
92corvette's Avatar
92corvette
When mine did that it was simply a bad radiator cap.
Hope that is your prob too.
Old Mar 20, 2003 | 01:54 PM
flyinace2000
Default Re: WIerd Noise (92corvette)
problem solved.....The overflow tanks cap was not on,,. i snapped it back down and drove her for about 25 min to get her all hot (sounds like a dirty story!) and no boiling over. So, so far so good :flag
Old Mar 20, 2003 | 01:56 PM
FoolCrzy's Avatar
FoolCrzy
:cheers:
To WIerd Noise
